| Допуски тормозных дисков Brembo для Mitsubishi Evolution |
| Hardwarest | |
| 20.11.2011 . | |
В данной статье указаны допуски износа тормозных дисков Mitsubishi Lancer Evolution 6-9. Using a micrometer, measure disc thickness ateight positions, approximately 45 degrees apart and 10 mm from the outer edge of the disc. Standard value: <Front> 32.0 mm <Rear> 22.0 mm Minimum limit: <Front> 29.8 mm <Rear> 20.4 mm NOTE: Thickness variation (at least 8 positions) should not be more than 0.015 mm. |
